- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1600
- Mark as New
- Bookmark
- Subscribe
- Permalink
AX1600
Don't buy 2. They will not work together.
Despite spending hours trying to get a solution, being told there is a solution....there isn't.
All it will do is completely destroy your wifi when you have both plugged in. One works fine. 2 is a train wreck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1600
If you have 2x mesh extends, yuo can potentially get them working.
What you need to do though is disable mesh for one of them and give it its own ssid. Or they can end up connected to each other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1600
Thanks and appreciate the response.
Thing is, and having spent 12+ hours with Netgear support on this, they can't tell me how to do this EVEN IF THEY KNOW.
The level of support and pervading ignorance of the support team is staggering.
When I raised a couple of issues they offered yo initiate 'Level 2' support, which says everything about the standard level.
No-one has ever suggested the solution you mentioned.
So I'll wear the $80 and get on with my life.
(Level 2 support would take too long for this to be economically viable)
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1600
L1 isn't much better than a standard big box store person.
One other thing to make sure if you're using them is they should be in a star configuration.
Star: extender<---------router--------->extender.
Not daisy chained
Daisy: Router-------->extender--------->extender
what issue were you having or running into?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1600
One connects.
Trey to connect the other and it:
- drops connection to the 1st.
- Kills the wifi, even though it only seems to pick up 1.
I'm done. This post was mainly as an FYI/warning to others.
One works fine, 2 is a car crash.
I'm staying with one as that seems to boost coverage somewhat and I'll live with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1600
Ok. Thanks for the fyi.
Last bit of advice, if you are trying to daisy chain (it'll reduce speeds significantly),
you'll want to go router---->extender (with unique ssid)---->then the extender setup with either router/or other extender ssid.
the mesh extenders don't have something controlling them so they can end up in a loop connecting to each other. Which is why one needs a unique ssid. If you're needing more coverage than the 1 extenders provides, look into mesh systems with a router controlling them such as Orbi or the MK nighthawk series.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
