Reply
AX1800 connectivity
cglov
Follower
AX1800 connectivity
I am trying to add a second extender AX1800-4 stream EAX20 and nighthawk app requesting an admin password for the Fios router.  I entered the password from the router sticker but error message does not accept the password.  I tried typing password in the password field as well, not accepting.  Please help
Message 1 of 2
Guru
Re: AX1800 connectivity
Are you sure you're entering the wifi login/password and not the info to log into the gui?
You can log into your router and check what your ssid/password is
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 85 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
