- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1800 wifi extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to extend my wifi coverage to my barn from my house. I have a good signal outside the metal barn. Because of the metal, there is no signal in the barn. Can I connect an external antenna to the AX1800 so I can attach it to the outside of the barn. If so, what antenna is recommended?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the questions. If you stick the antenna on the outside of the barn, what broadcasts inside it?
Usually what I recommend is something like a point to point (like netgears airbridge) system that lets you connect the 2 (house/barn) and then connect an access point inside the barn. That way you have a good connection between the 2 and something broadcasting inside the barn.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
