× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ac1200
Frits131053
Ac1200
Hallo,
My extender does not pas along the internet.
I did a reset and a new installation (2x) and the connection with the router is okay.
Still i don't get internet from the extender. The internet is functioning good direct on the router.
Any suggestions?
Tnak you,
Frits
Model: EX6150v2|AC1200 WiFi Range Extender
Message 1 of 3
Guru
Re: Ac1200
couple questions.
1. What firmware is on the extender?
2. the slide on the side for extender mode or AP mode? What is it setup in?
3. If you hardwired into the extender, does the internet work?
4. what are all the leds on the front doing? Color, blinking, solid, etc for each light.
5. How do you know the connection with the router is ok?
here's your support site with firmware, manual, and installation guide
https://www.netgear.com/support/product/EX6150v2.aspx
Message 2 of 3
Frits131053
Re: Ac1200
Thank you for reply.
1. Firmware V1.0.1.70
2. Extender
3. Tried this but also no internet through the extender
4. They are all solid green
5. The led for connection with my router is green
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 480 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
