- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ac1900 extender firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ac1900 extender firmware update
I suggest doing a factory reset on the extender, and then trying to set it up again.
You can find information on how to do the reset in the manual here: http://www.downloads.netgear.com/files/GDC/EX6150v2/EX6150v2_UM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I did that several times with no luck. I would have thought that it would autmatically connect as it always has...but in this instance, due to whatever changes in the firmware update...I had to go into the advanced settings and change to static from DHCP, then manually enter the ip address and gateway address, even though the fields were already populated with the correct info. It was just a lucky guess to manually re enter what was already there. So, in the end, I got all my devices working again...Thanks for the response though.
