- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Access Point Mode EXT7000 AC1900
- Mark as New
- Bookmark
- Subscribe
- Permalink
First off I need to correct an issue: where it says: Model (Recommended - Helps the community give the best answers) it dosen"t find my product whitch is clearly print in front of me says the following:
AC1900 Nighthawk
WiFi Mesh Extender
Modle EX7000.
Not R7000
anyways I came across a few posts asking about what is meant by the (Note: in access point mode, you can only connect your computer or WiFi device to the extender only using a WiFi connection.) This is only meant when your setting it up as a Access Point, its the only way to access the extenders settings. after I was done with the extenders access point setup and loged out of it, shut it down unpluged it and set it up in it permanent location, I plugged in 4 electronic devices IE: Onkyo TXRZ920,Sony BDP-S7200, PS3, PanasonicTC-L55DT55, ALL ONLINE and connected wireless via my ZTZ cell and my main wireless Desktop. ALL 6 online at the same time. This in my opinion is a superb NetGear product that has been running KNOCK ON WOOD Great for the 3 months I have owned it.
Sweety, Lowell & Daddy Tucson, AZ
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Access Point Mode EXT7000 AC1900
Thanks for your feedback.
The model selection is difficult because Netgear has so many. However, the EX7000 is on the list - I took the liberty of editing your post and correcting that.
