× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Actual Distance of 2500 sq ft Router
LSoares1
Follower
When a router states it has a 2500 sq ft coverage area, what is the actual distance it's suppose to represent?
The radius of a 2500 square foot circle is about 28 feet, so does that mean wifi should reach 28 feet from the router in all directions (including up and down)?
I understand obstructions like walls/floors can change this, but I just wanted to confirm if my basic understanding of this statistic is correct.
Thanks.
My Setup (Cable 1.2Gbps/50Mbps)>CM1150V>X6S>TP-Link TL-SG1024 (24port Gigabit Switch)
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 1630 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
