×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Add another N300 extender
davenicsnr
Recently changed broadband supplier and in order to ensure better wifi cover I purchased BT Mini Whole Home Wi-Fi - Three Discs. Not a good choice so returned to BT.
I have an N300 extender which gives good coverage upstairs but need more cover downstairs. Earlier this year it was recommended I connect a second N300 in the configuration shown
Extender........router........extender
Can someone explain how this is done?
i would have connected the second extender to the router but is this the correct sequence?
Would an N300 still be the extender of choice?
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 4
Accepted Solutions
Guru
Re: Add another N300 extender
here's the issue.
N300 is a single band 2.4ghz device. 2.4ghz is slow. And suseptible to interference.
And I usually recommend people move to a full triband mesh system if their needing more than 1 extender.
Reason why is extenders by their very nature drop throughput (speed) 50%. Plus you end up with another ssid name to have to switch to. It gets even worse when you add another extender to the situation with another ssid. And the speeds drop even more if you're connecting an extender to another extender.
tribands extenders don't suffer from the same speed hit and can use the same ssid as the primary.
This tends to make them more stable and easier to use.
Its even better with the triband mesh systems like orbi as their designed for it and have the router controlling the system.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 4
All Replies
Guru
Its just to ensure that the extenders are connecting back to the router and not to each other.
Easiest way is just to power off the other extender when you're setting up the new one.
Message 2 of 4
davenicsnr
Many thanks for your prompt reply.
Would you recommend same extender or perhaps one with greater coverage and compatible with the N300?
Message 3 of 4
Guru
here's the issue.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 360 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
