Reply
Adding MS80 to 3-pack AX3600
Ordnances
Follower
Hello everyone,
I am buying the Tri-band AX3600 3-Pack (MK83) to extend my home wifi, can this 3-pack be added with additional 2 Sattelite MS80 to the kit to make it work?
Thanks in advance!
Message 1 of 3
Guru
Re: Adding MS80 to 3-pack AX3600
I know you can add satellites but i'm not sure about the max satellites it'll support with the MK system.
With the orbi system, you see performance degredation after 6.
How many satellites can you add to an Orbi WiFi System? | Answer | NETGEAR Support
Maybe @Christian_R has more info.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hi Ordnances,
While we do recommend up to 2 satellites connecting to the router, we have seen some positive feedback from others being able to to have more than 2 satellites connected.
Christian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 92 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
