Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Adding WNDA3100v2 RangeMax Adapter to
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-30
03:10 PM
2012-07-30
03:10 PM
I bought a Netgear RangeMax WNR834Bv2 gateway in white, along with a RangeMax WNDA3100v2 dual band wireless-N adapter in black - back in Nov 2009. I was deployed shortly afterwards by the Army, and never had the time to hook it up until now - HOME FOR GOOD - HOOAH!!!!. My question is this - My gateway doesn't have the "Push 'N' Connect" feature, but the USB adapter does. I followed the instructions to a T & the installed went well, and much easier then I had expected too. Now is the LED on the adapter going to stay "Amber" colored all the time, because I don't have this "Push 'N' Connect on my gateway? And does this mean I do not have secure connection as well? Should I go with a different style of Netgear adapter? Thanks for everyone's help in this matter - 2nd Lt. LNS
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-07-30
09:21 PM
2012-07-30
09:21 PM
Re: Adding WNDA3100v2 RangeMax Adapter to
push N connect is called also WPS.
some of the old unit may have this feature enable while in the router interface but you can also use traditional encryption ( WPA, WPA2 ) and should connect.
make sure you connect with in the the same room or few feet away.
Message 2 of 2
Announcements
