× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
After Installation, network won't accept Key/pass phrase
REB64
After installing the extender, two new networks showed up (Centurylink****_2GEXT and Centurylink****_5GEXT).  I've tried entering the key/pass phrase from the router on _2GEXT and it won't accept it.  What's going wrong? -Eddie
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 5
Guru
Re: After Installation, network won't accept Key/pass phrase
Did you set it up using wps? WPS can get coded different between device manufacturer's (especially isp supplied devices).
What I'd try doing is factory reset the extender and then reinstall it using the installation assistant.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
REB64
I'll give it a go and see if that works.
Message 3 of 5
REB64
After resetting the extender, Netgear Installation Assistant was tried. I went to the connection manager and clicked on NETGEAR_EXT.  It tried to launch their website, but interenet connection was lost. Tried mulitple times to get on their website, it didn't work.  Hmmm...
Message 4 of 5
Guru
Have you tried a different browser?
Try firefox and/or edge.
if that doesn't work, try a different device for setup.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 306 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
