Reply
After changing my orange box 3 for a new orange box 5, Netgear AC1200 Dual band EX6130 doesn't work
Plumelec
Hello,
I have just changed my orange box 3 for a new orange box 5.
My Netgear AC1200 Dual band EX6130 repeater no longer works.
I followed the orange advice for this new instllation, but it doesn't work.
https: //assistance.orange.fr/objets-connectes/installer-et-user/extenders-et-repeteurs/extenders ...
I would like to know if I am missing something or if the repeater model is no longer suitable.
Thank you for your help,
Plumelec
Message 1 of 2
Guru
Re: After changing my orange box 3 for a new orange box 5, Netgear AC1200 Dual band EX6130 doesn't w
Have the EX connect to the orange box using it's SSID name and PW you have set up on the modem.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 108 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
