×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
After power outage Nighthawk X6s EX800 not work and all 8 lights are blinking
Sammy28
Initiate
Hi,
Had a power outage and now Ac3000 extender not working.  I just get all 8 lights blinking simultaneously.  Any ideas?
Thanks
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 4
Guru
Re: After power outage Nighthawk X6s EX800 not work and all 8 lights are blinking
Start with a factory reset.
Push and hold reset while powered on for 7-15 seconds. (sometimes up to 30)
If that doesn't work, the firmware might be corrupt.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
Sammy28
Initiate
I'll give it a try.  Many thanks!!!!
Message 3 of 4
Guru
Good luck!
If you do try tftp/nmrpflash, its sensitive to timings and can sometimes take a few tries.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 345 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
