× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
All green lights working but not working
Strapp
Tutor
I recently purchased the EX2700 extender and although I have all green lights on the extender is not working. I have selected my broadband_EXT on my IPad Pro and trying to improve the signal to my security camera outside using Cloud Edge. Not very good with computers and need help in layman terms. Thanks
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 8
Timmmo
Re: All green lights working but not working
Just had this with my EX2700 extender, in the end switched off main router, then after switching back on did the WPS button part of the install again and now all okay. Hopefully it works for you!
Message 2 of 8
Strapp
Tutor
Hi Tim
Thanks for the advice but I had already tried that and now in communication with Netgear Support trying to resolve the problem.
Message 3 of 8
Guru
What router are you connecting to?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 8
Strapp
Tutor
My router is supplied by Sky and I can receive a very clear outside picture from the security camera but the signal strength of 44% and is suggesting moving the camera to improve the signal strength, that is why I chose to install a WiFi extender!
kind regards
colin
Message 5 of 8
Guru
which sky router?
Are you using the installation assistant or WPS?
What firmware is on the router?
Message 6 of 8
Strapp
Tutor
Message to all who tried to help:
I contacted Netgear support and spent 35 minutes with them going through various procedures and finally carried out what they called a "Hard Reset" and finally managed to get the extender working.
Thank you all for your assistance 👍👍👍👍
Message 7 of 8
Guru
Glad to hear you got it working!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 638 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
