×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
AmA Handoff
beezer
Apprentice
AmA Handoff
Moving to a new office. I will have several Cat7 drops. The R6300v2 and R7800 listed in this post are the current routers (used as WAPs only) in my old office. Now...
I'd like to wire the WAPs and have romers do 802.11k handoff. I called sales ("We don't support it") and looked on the community boards (same info). Yet I know (or at least know the advertising says) that the EX8000 has it. So (a) what units are 802.11K capable, and (b) if the EX8000 is, then can I use it as a basic WAP through one of its RJ45's, and not the dedicated channel?
Any knowledgable input appreciated!
Model: R6300v2|AC1750 Dual Band Gigabit router,R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 5
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: AmA Handoff
Hello Beezer
Yes the ex8000 can do it and you may want to look at our business Access points.
DarrenM
Message 3 of 5
All Replies
beezer
Apprentice
Re: AmA Handoff
Adendum: Before I get this response in this forum too, I DID consider ORBI. The (confused) consensus is that wired backhaul is a work-in-progress, plus, I really don't feel the mesh mania. When someone in authority says wired backhaul works, I might use it in places just for esthetic reasons. Still, it feels like joining a cult and giving up fine control, just to get hand-off.
Message 2 of 5
DarrenM
Re: AmA Handoff
Hello Beezer
DarrenM
Message 3 of 5
beezer
Apprentice
Re: AmA Handoff
Thanks. I should mention this is a home office, but... suggest a business WAP for me, please?
Message 4 of 5
beezer
Apprentice
Re: AmA Handoff
Actually, as long as I'm asking for free pre-sales advice / consulting... Smiley Wink
I have a Linksys LRT224 (apostasy!). If I buy two WAC730s will I be able to:
1) Tune the power levels on the WAPs so they can be as close as 50 feet apart?
2) Set up a guest profile with a tagged VLAN for all bands (e.g., untag the non-guest LAN securely)?
3) Have the guest profile serve DHCP/DNS from the LRT224?
Bonus: Is there a better SOHO switch/firewall from Netgear, and what makes it good?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1256 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
