Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Automatic resseting issue EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-11-05
01:55 PM
2022-11-05
01:55 PM
Every week at the point my ex7700 extender is resetting itself and I will have to set it up again, no updates have fixed this and it's starting to become a big issue. Is there any fix? Should netgear replace this or look into it themselves as there's nothing about this issue online so I'm wondering if anyone has any fixes or also has this issue?
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-11-06
02:32 PM
2022-11-06
02:32 PM
Re: Automatic resseting issue EX7700
I've never had an issue like that.
1. what firmware version is on it?
2. have you actually factory reset it yourself and ran through setup? Maybe its a corrupt setting causing an issue and its not "fully" resetting but just loosing some settings.
3. did you set it up using the push button wps button or using the installation assistant?
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-11-06
02:52 PM
2022-11-06
02:52 PM
Hi, thanks for the reply! <br>It's currently on V1.0.0.226 which I believe is the latest and I have reset it fully before which didn't change anything. When setting it up again I do it through mywifiextnet as normal either through connecting via wifi or ethernet <br> and it works until it doesn't which is obvious very strange.<br>Thanks alot!
Message 3 of 3
Announcements
