× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Barely works
sinusoid
Barely works
It worked perfectly at my old house. Moved it and it is extremely slow in everytjingf it does. Had to go through the setup numerous times, and even did a factory reset on it. Set it up in the same room as my router, it when I moved it to another room any connection speed is very sluggish before it cuts out. I can't connect to it at all after that. Phone has perfect wifi connection in the same spot.
Any suggestions? I updated the firmware, but that didn't change anytning.
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: Barely works
Hello Sinusoid
Have you tried to change the wireless channel?
DarenM
Message 2 of 5
sinusoid
Re: Barely works
On my router or range extender? Wifi on other devicces works fine from the router, but the extender can barely connect, and when it does the hardline connection from it is verybweak
Message 3 of 5
DarrenM
Re: Barely works
On the router.
DarrenM
Message 4 of 5
sinusoid
Re: Barely works
Even though all other devices do not have the connection issues, even in the same location?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 649 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
