mondrin's avatar
mondrin
Guide
Oct 12, 2020
Best mesh extender for Comcast xb3?
I've got the Comcast XB3 modem/router that does not provide a stable 5GHz signal to my back rooms.  These rooms are maybe 50 feet from the router and pass through 3 or 5 walls.  My router does not do AX and since I only have 350Mbps service, won't be getting an AX router (I do have 3 devices which support AX).  I've been looking at the EX8000, EX7000 and the newer EAX20.  I know the EX8000 and 7700 should mesh with my current router.  Does the EAX20 do this, being it's only a dual band?  I currently have my 2.5 and 5GHz channels separate on the XB3 and don't trust it's steering capability.  Can any of the extenders mesh each channel individually?
Thanks!
1 Reply
  • plemans's avatar
    I'd recommend the EX8000 or EX7700.
    both are triband extenders. The benefit to tribands is that they have a dedicated 5ghz chip just for router---extender communication.
    Most standard extenders (dual and single band) take a 50% speed hit because they have to use the same chip for router---extender communication and then extender-----device communication. And they can't do both at once. Because of the dedicated chip, the tribands don't take that speed hit.
    The XB3 isn't a AX router so upgrading to an AX extender isn't going to be much benefit because the connection back to the router is still an AC connection.
