× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
C3700 cable connection in progress?
Silipaq
Follower
Hello, I need some help by what the subject says, my cable connection on the (netgear genie) says it's in progress...can anyone help me understand by what that means, I've tried resetting my router and doing a hard reset but nothing seems to be working. Now I'm left without internet.
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 3
Guru
Re: C3700 cable connection in progress?
Click on that icon.
It'll show up your cable connections page. That'll show us your connections/strengths and potential issues.
if you have any splitters/attenuators/amplifiers in the line, remove them. also make sure your cable connections are tight and that you aren't using cheap/corroded ends on them. You can also check for kinked/worn coax cables. These can all create connection issues.
Message 2 of 3
Guru
If you do have the c3700, this is the forum for modem/router combo devices:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
You're currently posted in the wireless extenders section.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5462 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
