× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can I extend 2 separate network with the same extender?
Loccife
Hi, can I use the  AX8 Wi-Fi extender to extend 2 separate network? One on the 2.5 band and a separate on the 5?
thanks
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: Can I extend 2 separate network with the same extender?
yes it extends both networks. If you want them seperate so you can see each individually, just disable "one wifi"
Thats the feature that combines the ssid into one and lets devices roam between 2.4ghz/5ghz as needed.
https://kb.netgear.com/000044732/How-do-I-enable-or-disable-One-WiFi-Name-on-my-Nighthawk-Mesh-WiFi-...
Message 4 of 4
All Replies
Guru
What model do you have? AX8 isn't a model number.
Theoretically you can. When you're using the installation assistant, it lets you choose which network to connect to and extender.
You should be able to select different ones. Keep in mind you won't be able to set it up as a mesh device though.
Message 2 of 4
Loccife
Hi, thanks for your reply. it's an EAX80-100EUS used as a single extender device. Apart from the original router (Fritz box 7530) I don't have any other devices in house.
basically I want to extend the home Wi-Fi network coming from the router on the 5GHz, and the security cameras network on the 2.4GHz.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 857 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
