- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can I use a wireless wifi extender to replace a long ethernet cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Arris dual band cable router provided by our cable service company and have a couple of ethernet-connected pcs and some wireless devices connected to it. Our typical download speeds are 30-40 Mps, exactly what we pay for.
My laptop has a wonky wireless network adapter card in it, which I'm trying to work around rather than replace. Rather than run a 30 foot ethernet cable from my laptop to the router, could i use wireless range extender like your N300 or AC750 in the same room as my laptop, and just use a short ethernet cable between the extender and the laptop?
Would I expect to achieve the same speeds and response as I currently get using the wireless adapter in my laptop?
thanks very much for any advice.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry for the misunderstanding.. The EX6100 can be used as a range extender, or an Access Point. In Access Point mode, you would get the better performance / throughput, by using an Ethernet connection between router and EX6100. In Extender mode, you lose about 50% throughput. With any Extender you take about a 50% throughput loss because of its nature.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can I use a wireless wifi extender to replace a long ethernet cable?
What is the model number of your routers? N300 and AC750 are wireless standards, which just about every vendor makes at least one..
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's an Arris TG1672.
- Mark as New
- Bookmark
- Subscribe
- Permalink
the netgear models I saw, for example, were one such as EX6100 or EX3700, or whatever would be suitable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks very much, that's exactly the type of information I was looking for. Sounds like I'd be better off just running a long ethernet cable to the router, or open up the laptop and replace the network adapter.
