superkoko00
Aug 31, 2020Follower
Can I use my range extender (EX6130) as wifi client?
Hi all,
I have a range extender (it's EX6130, not EX6120, but my model isn't on the list). I'm interested in using it as wifi client, without repeating the wifi signal. I only need it to connect a decodifier that hasn't wifi, so I want to use the extender as wifi antena for it and connect the decodifier to it using an ethernet cable. The router is too close to the place where I want to install the device and I prefer to not repeating the signal if possible.
Is it possible? I haven't seen the correct configuation to do it.
Thanks!
No RepliesBe the first to reply
