ral222
Jul 16, 2017Follower
Can a EX7300 connect to a U-verse Wireless TV receiver?
My wireless signal strength is weaker than I would like. I'm thinking of swapping out my U-verse provided Cisco VEN501 Access Point with a Netgear EX7300 for more power. My question is will I be able to connect my U-verse Wireless Receivers to the Netgear AC2200. I plan on using the Netgear in Access Point mode.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello ral222
You should be able to if all they require is a a wifi connection.
DarrenM
