× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can no longer connect to 5G network after firmware upgrade
ssi112
I upgraded my Nighthawk X6 AC3200 to the latest firmware version: V1.0.4.28_10.1.54
Now I can no longer connect to my 5GEXT network.
My laptop doesn't even show the network any longer.
On my smartphone it says "Failed to obtain IP Address"
I Enabled Smart Connect then restarted the modem, router, and extender.
The result is the same.
How can this be fixed?
Thank yo
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Can no longer connect to 5G network after firmware upgrade
Have you tried to disable smart connect and rename the 5ghz network and see if the network shows back up?
DarrenM
Message 2 of 3
All Replies
DarrenM
DarrenM
Message 2 of 3
ssi112
It took a couple of reboots of the extender, but renaming the networks appears to have worked.
Thanks
Message 3 of 3
Discussion stats
  • 2 replies
  • 667 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
