Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't access netgear 3700v2 by wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-04
01:44 PM
2012-11-04
01:44 PM
I have problem with my router 3700v2. I can't access my router by to config it. Ig i want to config something in my router, I must to use wire. It didn't like this when I bough it. I don't know what is wrong with it. can somebody help me?
P.s: sorry for my bad english.
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-07
11:08 AM
2012-11-07
11:08 AM
Re: Can't access netgear 3700v2 by wifi
To access the web interface from a wireless pc you have to be connected first to your wifi network. So at first you have to configure the wifi network and assign the SSID name and the type of autentication like WPA ecc. and provide a passphrase.
If you are already connected and you can surf the web try to connect to your router with the ip address you configured in the lan setting. E.G. if you router address is 192.168.1.1 if you write this address in the browser address and hit enter the router should give you a login windows with prompt for user and password. If the windows does not show up may be your security firewall rule prevent you pc to use port 80 with the router address. So check the security configuration of your router.
If in trouble try to upgrade the firmare to the lastest release and reset the router to the factory default as directed in the manual.
May be that you messed up the firewall configuration and locked out some or every wireless station.
hope this help. Bye
hope this help. Bye
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-07
11:20 AM
2012-11-07
11:20 AM
zaRos wrote: I don't know what is wrong with it. can somebody help me?
You are not really specifying the issues to give you what you need to do
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-07
11:22 AM
Announcements
