× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can’t complete setup on network extender
Srisley22
I have model EX6150v2 / AC 1200 Dual Band Range wifi extender.
(couldn’t find my model on the list)
Setup via WPS didn’t work so I opened installation assistant via my mobile device. I’m able to find and select my personal wifi network, but the “Next” button isn’t active to allow me to go to the next step.
I can only select my wifi when 2.4 GHz box is checks.
Cannot select “Next.” What am I doing wrong? Is the device not compatible with my wifi router?
I’m a chick and not very tech savvy so simple terms and advice is appreciated.
Model: EX6000|AC750 Dual Band WiFi Range Extender,EX6150|AC1200 WiFi Range Extender
Message 1 of 6
Guru
Re: Can’t complete setup on network extender
The extender model is listed, I selected it in my reply.
There should also be a 5 ghz radio that is checked, and you'd need to either uncheck it or select a 5 ghz network name to extend.
Can you try scrolling down, and see if you can find that?
Model: EX6150|AC1200 WiFi Range Extender
Message 2 of 6
Srisley22
I don't have an option to select 5 ghz. When I scroll, I only see other wifi networks or can select manually entering SSDI networking info.
Message 3 of 6
Guru
Are you using the web browser in the phone to access the extender?
Another thought is that you could try removing the spaces in the router network name.
Message 4 of 6
Srisley22
I was able to complete set up using a laptop and following the mobile device instructions since my laptop is too thin, without an ethernet port. Set up would not complete at all using my monile device.
All squared away now. Thank you!
Message 5 of 6
Guru
FWIW, you can get USB ethernet adapters (including USB-C).  It might be worth picking one up.  I use one with a Yoga (also no ethernet) when I back it up.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1980 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
