× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can’t connect devices to extender
leroy03
I have set up my extender and am ready to use it. However, when I try to connect my devices, it tells me my WiFi password is incorrect. I am using the same password as I always do for my regular WiFi modem. Any ideas of what to do?
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 8
Guru
Re: Can’t connect devices to extender
What router did you set it up on?
what firmware is on the extender?
did you set it up using wps? if so, try factory resetting and reinstalling using the installation assistant.
Message 2 of 8
leroy03
It’s linked to a century link router and I did use wps to link it.
Message 3 of 8
Guru
which centurylink router?
Have you tried reinstalling it using the installation wizard? (Not wps)
Message 4 of 8
leroy03
It is a 802.1 1n router through century link. I have not tried the other method yet.
Message 5 of 8
Guru
centurylink has many routers. An actual model helps.
But try the installation assistant first
Message 6 of 8
leroy03
I can’t use the installation assistant because my laptop won’t connect the the extender.
Message 7 of 8
Guru
Where is it failing in the process?
What error is it giving you?
Did you try factory resetting the extender? push and hold reset for 7-15 seconds while its fully powered on?
Message 8 of 8
Discussion stats
  • 7 replies
  • 816 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
