× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't connect ex6400v3
Dsmvr4
The NETGEAR_EXT won't show up on my wifi list. I've been trying for hours. I can't setup my extended without connecting to that network.
Message 1 of 3
Guru
Re: Can't connect ex6400v3
The EX6400v3 is a mesh extender. meaning its default configuration sets it up using mesh.
Mesh means it uses the same ssid as the router and lets devices roam between it and the router as needed.
Is that how you set it up? (WPS sets it up this way).
Message 2 of 3
Dsmvr4
Yes. In the setup app I get to the step "allow suggested wifi networks". I click "allow" but NETGEAR_EXT never appears on the list. I've waited for hours, and I've restarted and attempted setup more than 20 times. Until I select NETGEAR_EXT from the wifi networks list, it will not complete the setup for the extender or mesh the wifi signal.
Message 3 of 3
Discussion stats
  • 2 replies
  • 504 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
