× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Can't connect extender to 5GHz band on EX6120
jbaugh
I'm trying to set up a range extender.  I've tried now at least 8 times to do this.  I can get the extender set up to work with the 2.4GHz band but not with the 5GHz band.  The 5GHz band always gets a self assigned ip adddress and states "unable to connect to internet". I have another model of the extender that connects with no problems.  I suspect a defective device.
John
Message 1 of 3
Guru
Re: Can't connect extender to 5GHz band on EX6120
To clarify - is the problem you have connecting the extender to the router network?  Or is it connecting a client to the extender network.
If it's about connecting the extender to the router:
  • does your working extender make a 5G connection if you move it to the EX6120's location?
  • Is the router LED lit?  If so, what color?
If it's about connecting a client to the extender:
  • Are you using FastLane?
Message 2 of 3
jbaugh
Problem is making a connection from extender to router on the 5GHz band. No problems configuring on 2.4GHz. When I try to join the extended 5GHz network from a device I get a message saying “not connected to internet. If I view the connection parameters I find that there is a self assigned ip address and no entry in the router ip line. After many attempts I finally connected via the 2.4 GHz band and configured the extender with FastLane. Everything seems to work so I think I will let well enough alone. Thank uou for taking the time and effort to help me.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1243 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
