- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't connect my extender to ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I have my wifi router in the halway, adn my extender in my room, it's working but the signal is weak... I thought I would be able to just plugg the extender in with a ethernet cable, but when I do I get a exclamation mark over the wifi icon and the signal comming from the wifi router in the halway seems to get jamed too. What on earth am I doing wrong? Plz and thank you.
-Danny
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you hardwire in the extender, you need to rerun setup and set it up using access point mode and not extender mode. Or you will run into issues.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't connect my extender to ethernet.
Cool I'll try that right away thank you. Hope it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
after two weeks of extensive suffering this solved my issues....
not very easy to come by this info... thnx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well glad it was an easy fix for you!
Let us know if you have other issues
