Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can’t connect wifi extender to network
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-03
09:51 PM
2021-12-03
09:51 PM
Hi, I’ve just purchased a AX1800 Wi-Fi extender.
I’m trying to connect it through the app. I wait for the green light, but the Netgear_ext doesn’t come up in my list of networks to select in the wifi settings.
All 4 lights on the extender are green I’ve made an account. I don’t know why the name won’t come up in the list to select. The app keeps telling me it can’t find the extender. I’ve troubleshooted everything and can’t fix it.
Does anyone know how I can solve this?
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-12-04
11:28 AM
2021-12-04
11:28 AM
Re: Can’t connect wifi extender to network
A couple things.
1. What AX1800 do you have? AX1800 is a speed, not a model. So what model is it?
2. usually if all the lights are green, it means its connected to the router. Did you try setting it up using wps first? if so, all the AX1800 extenders are mesh extenders. meaning they use the same ssid as the router. So if your "router" led is lit up green, its connected to the router. I'd be curious if you have set it up and just weren't aware of how mesh worked
Message 2 of 2
Top Contributors
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
