bthcw's avatar
bthcw
Follower
Jan 04, 2020
Can't create account after reset WIFI range extender
Hi guys,
I updated the framework of my wifi extender to lastest version two days ago and reset the extender. After going to setup wizard, it ask me to create a new account. I typed all the infomation without any error tips, but when I clicked the "Next" button, nothing happened.
My wifi range extender is EX6200|AC1200 Dual Band.
Does anyone meet this problem before or know how to solve this problem? Thanks a lot!!!
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi bthcw,
    Can you confirm that you are using your MyNETGEAR credentials to login or have you tried logging in with the default admin credentials listed below.
    Username: admin
    Password: password
    Christian
