× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Can't log in to extender using router password
Hosepipe
Follower
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: Can't log in to extender using router password
Are you trying to connect to the extenders wireless or are you trying to log into the extender's user interface?
Have you setup the extender?
What are all the led's on it doing? (describe each one, color/blinking)
How did you setup the extender? Did you set it up via wps or did you set it up manually?
have you tried manually reinstalling it? You can factory reset if by pushing reset while powered up for 7-10 seconds until the lights change. Then try following the manual reinstall guide.
There's also the support site that has more info such as guides, firmware, manuals, and troubleshooting.
https://www.netgear.com/support/product/EX6110.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 448 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
