× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Can't login to N300/EX2700
Velms
Follower
Solution to this is:
Connect to netgear ext on wifi before trying WPS or after factory reset.
As the previous link suggests ignore the pop up box for registration. Open a window on chrome or safari or whatever. Type the router IP address and this links you to the same page .
192.168.1.250.
Put in your details and your in.
I triehad the same problem as others after having registered the standard way with the pop up box but I couldnt log in. So I tried this and bingo!!!!!
Message 1 of 2
additude
Virtuoso
Re: Can't login to N300/EX2700
Thanks for the update and feedback.
I'm sure this will be helpfull to others.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 766 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
