× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Can't login to WN300RPv3
JK50
Tutor
My extender has been working for more than 1 year, but it recently began displaying problems. The connection with the router was disrupted after I reset the router.  Since then, when I try to connect a device to the extender, it says that I have to login to the extender. When I click on the extender icon to login, it displays the following text: {"reset"; "1"}. I've performed a Factory Reset more than once, but it continues to behave in the same way. Can anyone suggest what I should do now?
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 5
Guru
Re: Can't login to WN300RPv3
what router do you have?
Did you install the extender using wps?
If so, after a factory reset, reinstall it using the installation assistant and NOT wps.
Message 2 of 5
JK50
Tutor
I don't think that you understand my problem. I'm trying to use the installation assistant but I can't connect to the extender because it doesn't display the login page, only the text shown in my description.
Message 3 of 5
Guru
Have you tried a different pc or browser?
Message 4 of 5
JK50
Tutor
I tried using my Android phone (instead of the Android tablet) and that appears to have worked. Maybe the problem is with the tablet. I'll have to monitor this one.
Message 5 of 5
Discussion stats
  • 4 replies
  • 850 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
