- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot connect Acer Aspire to Range Extender (WN2000RPT)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I recently bought an Acer Aspire One A150 ZG5 from eBay. It works really well and will connect to every wireless network I've tried apart from to the Netgear Range Extender I have at home (WN2000RPT). I can connect to my wireless router at home (a Netgear DG834G) without any problem but that doesn't have enough range that I can use the Acer in another room. I have other devices connected to the WN2000RPT (iPad, Tivo and I brought home a laptop from work to see if it could connect - it could).
So I'm puzzled. I've checked all the settings on the Acer and it doesn't seem to have any trouble, as I say, connecting to any other wireless network; it's just the WN2000RPT it has a problem with. I can see the WN2000RPT on the list of wireless networks on my Acer, I try and connect but it always fails. When I run diagnostics it tells me either that there is a problem with the router and to turn it on and off again, which I do, but then sometimes the error is that it's unable to obtain an IP address, but usually the message is that the Network key on the Extender and Acer don't match. I know that's not right as I put the password into Notepad and copied and pasted it. I've also typed it in about 30 or 40 times but somehow it always gets rejected. All the green lights on the Extender are on and it works fine with all other devices. Any suggestions? I can mail the diagnostics report if that helps (the forum wouldn't allow me to post it here as it was too long). This bit at the end may be important though:
"Error renewing the IP address: The DHCP client has obtained an IP address that is already in use on the network. The local interface will be disabled until the DHCP client can obtain a new address."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot connect Acer Aspire to Range Extender (WN2000RPT)
Delete wireless from list and re-enter "KEY"
I've also typed it in about 30 or 40 times but somehow it always gets rejected this to me would suggest security is not supported try another other than WPA and or WPA2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the manual for the WN2000RPT (ftp://downloads.netgear.com/files/WN2000RPT/Documentation/IG/WN2000RPT_IGPM_30_Nov10.pdf) it says that I should be able to connect to www.mywifiext.net or www.mywifiext.com to change settings on the WN2000RPT but when I try to do that the browser just times out.
I'm very puzzled. By the way I did check 'obtain IP address automatically' was checked. It is. My Acer is still unable to connect to the WN2000RPT but it can connect to the main router and any other wireless network I've tried it on.
Any other ideas? Shall I try updating the driver for the wireless card on the Acer anyway?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
