MichaelC1234's avatar
MichaelC1234
Follower
Apr 07, 2020
Cannot connect EX2700
I am having difficulty connecting my N300 EX2700 wifi extender. My router is Rogers Hitron CGN3ACR.
I have tried the WPS button which doesn't work. I have performed factory reset multiple times both when plugged in and not plugged in. I have performed a factory reset of my router which hasn't helped.
When I perform the manual setup from a factory reset, I can get to the point where it tells me to log into the new network then hit "Continue". When I do so it takes me back to the login page. I no longer see a success page. When I log in again it takes me back to the beginning of the manual setup but this time it tells me that the extender could not establish a connection with the router. I have tried skipping this part to continue with the rest of the setup but am unsuccessful.
So no matter what I do now, I cannot get it to connect to my router. I have tried multiple devices, multiple browsers, have performed many factory resets, and am basically stuck.
Thanks in advance.
No RepliesBe the first to reply
