× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cant find router in Nighthawk app
hanneske26
Tutor
With the latest app update
i cant connect my mighthawk app with the Extender EX8000
The extender is working but the nighthawk app cannot find the router
i can login with browser in extender and all is working well
but the app cannot connect??
already performed factory reset on the Extender , then new installation but the nighthawk app won't find the extender in installation proces even when connected to netgear_ext wifi
Extender configured with browser and extender is working great again
but not with the nighthawk app
Any suggestions
Message 1 of 6
Guru
Re: Cant find router in Nighthawk app
Are you using a iphone?
If so, make sure to disable icloud relay, random mac, random ip.
I've seen them cause a slot of issues lately
Message 2 of 6
hanneske26
Tutor
I'm using i iphone
tried the solution disable iCloud, ip en mac but that doest do the trick
johan
Message 3 of 6
Guru
Tried uninstalling the app and reinstalling?
It works fine through the browser though?
Message 4 of 6
hanneske26
Tutor
Yes tried that to but app wont find extender
And yes works fine trough browser but the app cant Connect
Message 5 of 6
santosmarco
I have the same problem over the last 3 weeks, same exactly issue.
Nothing fix the issue, I am waiting a next app update to see if they fix that.
Everything is working perfect on the browser and also I checked with my network monitoring tools (FING and WireShark)
PS: I have this same apps installed on Android device, and it work without any problem, the issue is related to the iOS version.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1384 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
