× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Change backhaul frequency
MSBayou
My EX8000 is currently running 2.4Ghz backhaul. How do I change it to 5.8Ghz? Am I correct that 5.8Ghz backhaul is preferred?
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Range Extender
Message 1 of 2
Guru
Re: Change backhaul frequency
Usually yes, but if the extender is too far from the router then 2.4 ghz might be best.
Does your router use a different SSID for each band?  If so, you can configure the EX8000 to use the appropriate SSID.
Message 2 of 2
Discussion stats
  • 1 reply
  • 633 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
