× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Change name for better security XAV 5421 - AV 500
wyko
Hi
I have a Powerline wifi extender with a default name NETGEAR_EXT that works ok
I understand this is not secure
I would like to rename the extender device with the same name as my router to provide a single reference point and make the access secure
Regards
Graham
Model: XWN5001|Powerline 500 WiFi Range Extender
Message 1 of 2
Guru
Re: Change name for better security XAV 5421 - AV 500
the manual goes over how to log into it to change the ssid.
https://www.netgear.com/support/product/XAVB5421.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 458 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
