× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Compatability
MIchaelNC
Compatability
I currently have a Nighthawk X6, Powerline 1000 & Nighthawk X4 AC2200range extender.My initial setup consisted of he router and powerline but that didnt see to do what I wanted to do which was have a stronger signal in my lower level. I purchased the AC2200 thinking I could use that in conjuction with the existing setup but that doesnt seem to doing the trick. My question is do I replace the Powerline 1000 with the AC2200?
Model: EX7300|AC2200 Nighthawk X4 Wall-plug Range Extender
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Compatability
Hello MichaelNC
When you say stronger signal are you saying better wifi coverage or more speed?
DarrenM
Message 2 of 4
MIchaelNC
Re: Compatability
I would say better coverage, speed is determined by your provider, no?
Message 3 of 4
DarrenM
Re: Compatability
Hello michaelNC
Well when you use a extender via a wireless connection you can lose up to 50% of your speed when you are connected to that extender but if you are able to run ethernet to it and use it as a AP you would be fine.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1855 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
