×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Compatibility between WN3000RPv3 and XAV5201
p_solon
Follower
Hello There,
I have rescently bought a WI-FI extender model WN3000RPv3 which is working very well but my son has given me another adaptor (XAV5201) which was part of a set of 2 (which is supposed to work with the XWN5001). My son only gave me the XAV5201 as the other adapter (XWN5001) was lost while moving back from college.
I was wondering if I can use this second adaptor (XAV5201) to extend the range of my network by connecting it to the WN3000RPv3. Are they compatible? If so, any idea on how I should install the XAV5201 to extend my network? I apologize for the basic questions but I am not an expert on these things and am affraid I may not be able to get them to work in case they are compatible without some help.
Thanks
Message 1 of 2
nhann
NETGEAR Employee Retired
Re: Compatibility between WN3000RPv3 and XAV5201
Hi p_solon,
The powerline comes with two devices like you mentioned. You will need both devices for it to function properly with the extender.
Please see the installation guide:
http://www.downloads.netgear.com/files/GDC/XAVB5201/XAVB5201_IG_31MAY2012.pdf
Message 2 of 2
Discussion stats
  • 1 reply
  • 2468 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
