- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Compatibility
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can I use the Nighthawk X4S Tri-Band WiFi Mesh Extender with my Nighthawk X6 AC2200 Tri-Band WiFi Mesh Extender?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
that usually works the best. they're both triband extenders so will use the backhaul channel for connecting to the router. The only time there's an issue is if the extenders are to close to each other and try to connect to the other extenders wifi instead of back to the router.
If this happens, all you'd need to do is change one of the extenders to a unique ssid for differentiation.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Compatibility
You want to go: router--->ex7500--->ex7700? A daisy chain setup.
it should but every hop in the connection is going to add latency. I'm not sure if you'll see a speed decrease or not because of the wireless backhaul of both devices. I've never used more than a single triband extender. Usually when people are needing more than a single extender, I recommend the orbi setup that's designed for both star and daisy chain configurations.
Any chance of going: EX7500<---router--->EX7700? its a star configuration and tends to have less latency.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Compatibility
Yes, I would like to go EX7500<---router--->EX7700?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
