× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Configuring the extender
ramani
Follower
Can you please let me know how to configure the extender through the browser. The user name of "admin" and password of "password" does not work at all. Please help. Also, is there a possibility of someone else entering into my network through the extender as the data consumption has suddenly increased after connecting the extender through WPS. I would like to change the password of the extender to try to prevent this .
Model: WN3000RPv2|N300 WIFI Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Configuring the extender
You will have to factory reset the extender by holding the reset button for 10+ seconds then the default login should work for you again and you will be able to change all of those settings.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 354 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
