× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connect Ethernet switch with several PCs to WN3000RP Ethernet port
davidmoulet
Follower
My question is if it is possible to use the Ethernet port in a Repeater/Extender to connect a Switch with several devices as PCs, etc. This repeater is connected wirelessly to a router and Internet.
I have a WN3000Rp, but I dont mind to buy a newer product if it turns out that the answer i NO for my olf 3000Rp and YES for a newer product.
Thanks
davidmoulet@yahoo.com
Model: WN3000RP|Universal WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Connect Ethernet switch with several PCs to WN3000RP Ethernet port
Hello davidmoulet
You can do that if you have enough bandwidth after extending your network for all of those devices.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2132 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
