bsaikido
May 15, 2020Follower
Connect X6s mesh extender to an ASUS 2400 router
I'm trying to set up this Mesh Extender. My router is an ASUS 2400 model. The WPD is not working nor is the NetGear App. is there any other way to set this up?
1 Reply
You can connect to the extender either via wire or wireless and set it up using the installation assistant.
this guides for the ex7300 but its pretty much the same fo the ex8000
