× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connect extender to AP
avanard
I have one EX6100 hard wired to the main rounter in AP, I know I can't daisy chain wifi extenders. However, I would like to know if it is possible to connect a second extender, if the first is in wired AP mode?
Model: EX6100|AC750 WiFi Range Extender
Message 1 of 4
TheEther
Guru
Re: Connect extender to AP
Yes!  You can have as many APs connected via Ethernet as you want.
Message 2 of 4
avanard
TheEther, thanks for the quick answer, but that was not my question.
I'm NOT trying to connect addional APs via etherent.
I want to extend the the APs wifi (ex6100 in AP mode, connected via ethernet), with a second ex6100 in extender mode (No eithernet just wifi)
[Router] --> EHTERNET -->[ex6100 in AP mode} -> ))) ->wifi -> ))) -> [ex6100 in extender mode]
The reason I am asking this is the Knowledge base  article linked below says
  • Range extenders are not designed to be daisy-chained. You can use multiple extenders but their main source of wireless connection must be the same. You cannot connect an extender to another extender's wireless network.
I want to know if that is still the case if the first extender is in AP mode.
http://kb.netgear.com/app/answers/detail/a_id/24801/~/what-is-a-wireless-extender%3F?cid=wmt_netgear...
Message 3 of 4
TheEther
Guru
That should work.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4832 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
