Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting but no access...
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-06
03:09 AM
2011-10-06
03:09 AM
If the title makes any sense :confused:
Anyway, I have been successful in setting up the WNCE2001. The unit is obtaining an IP Address (have set it to static also to see if that helps) and the image shows that it is connected to the local network as well as the Internet. All three lights are solid.
But on my Samsung BD550 blu ray player no icon for the Internet shows.
Does anyone else have this model Blu Ray or similar?
Does anyone have any idea as to the problem as to why I cant get access?
Any help appreciated.
cheers
col
cheers
col
Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-06
12:02 PM
2011-10-06
12:02 PM
Re: Connecting but no access...
Oops...my bad, the make is LG and not Samsung...apologies for any confusion 😮
cheers
col
cheers
col
Message 2 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-06
07:57 PM
2011-10-06
07:57 PM
As I am unable to edit the post I will add some more info here...
I am able to check for firmware updates wirelessly...but the update doesnt download for some reason...
Would welcome any pointers...
cheers
col
cheers
col
Message 3 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-06
08:39 PM
2011-10-06
08:39 PM
setup static IP on player side.
use ISP DNS and try, if still the same, use GATEWAY IP listed under the router interface and fetch from the WAN/internet port information and use that for gateway in player side
Message 4 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-06
10:08 PM
2011-10-06
10:08 PM
jmizoguchi wrote: setup static IP on player side.
Thanks for the reply...will try the steps you have outlined above as soon as I get access to the password for the router (shared house and the password is kept somewhere unknown to those that are here at the moment) :mad:
cheers
col
Message 5 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-09
01:08 AM
2011-10-09
01:08 AM
Heres an update that may mean something...played a DVD on the BD550 this afternoon and before shutting it down I thought I would check the Internet connection. As per usual it reported that the connection was up. I then went into the software update area and tried the update and it worked. It downloaded and installed the update.
My question is if it is able to download the update then why cant I access anywhere else?
BTW I will be trying the steps outlined above as soon as the person with the password to gain access to the routers settings makes an appearance...
cheers
col
cheers
col
Message 6 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-09
05:09 AM
2011-10-09
05:09 AM
that is hard to say. if updates works I would think rest should work.
Message 7 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-09
03:33 PM
2011-10-09
03:33 PM
jmizoguchi wrote: that is hard to say. if updates works I would think rest should work.
Have sent a message to LG in the (remote) hope that they may be able to shed some light on what is going on...in the meantime I will try the above suggestions you made...
cheers
col
Message 8 of 8
Announcements
