- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting to internet with Ex6120 (AC1200)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just set up my new range extender (model EX6120 - Dual band extender) however everytime I attempt to connect to it (on either band), it asks for the security key, after it accepts it, it then pauses then notifies me of one of two things:
first is http://i.imgur.com/XooZ7NA.png Indicates "Some information changed since you connected. We need additional information to complete the connection" (Note: Have gone through the set up process multiple times trying to figure this out.) - when you enter the security key in again you get the same message.
The second notication is http://i.imgur.com/gU8Qt8Z.png - which simply indicates that it cannot connect to the server.
The range extender is currently plugged in roughly 1' away from the modem/router and my computer was on a desk directly above them and the setup indicated that it was completed (multiple times)
Would someone explain what I am missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting to internet with Ex6120 (AC1200)
Hello Rxmichele
You may want to get the latest firmware from the support page an update the extender the other thing is to factory reset the extender and try to do setup again in case some setting got messed up the first time during set up.
https://www.netgear.com/support/product/EX6120.aspx?cid=wmt_netgear_organic#download
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried to download the firmware the encountered this:
http://i.imgur.com/V4Q68FV.png
before it unzipped
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Rxmichele
You will want to load the .chk file onto the extender to update the firmware. You will want to log into the extender then go to Maintenance then firmware update there you click browse and select that file. Make sure you are connected to your extender via Ethernet when updating to no corrupt your install.
DarrenM
