Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection to network but not internet on one device
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-24
11:40 AM
2014-07-24
11:40 AM
Hi,
I recently got a WN3000RP. I found the set up easy and was able to connect all my devices (pc, laptop, phone). I set up the extender on my pc as this was the main reason I bought it due to a weak wireless card.
It worked fine until I turned off my pc, when I turned it back on it connects to the SSID_EXT but does not connect to the internet. All other devices I have tried are able to connect to the internet just fine through the SSID_EXT network.
I moved my pc into range of the router and it also can connect to the internet fine through that network. Can anyone help me on this???
Message 1 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-26
02:45 AM
2014-07-26
02:45 AM
Re: Connection to network but not internet on one device
Can the PC connect to the WN3000RP by LAN?
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-28
08:45 AM
2014-07-28
08:45 AM
michaelkenward wrote: Can the PC connect to the WN3000RP by LAN?
Yes it connects to the LAN but not to the internet. All other devices I have connect to both.
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-28
01:47 PM
2014-07-28
01:47 PM
If you just want to connect wired on your pc I suggest you disable the wireless card.
Please check if the local adapter is set to dynamic or static.
Is it a valid IP address within the router's range?
Also check if the DNS address.
If DNS not pingable try to set a static DNS on the extender using the router's IP address.
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-08-09
03:47 AM
2014-08-09
03:47 AM
Hello,
I have the same problem, I can connect to the WN3000RP but i haven't got internet.
What can i do?
Thanks
What can i do?
Thanks
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-08-12
10:54 PM
2014-08-12
10:54 PM
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-08-18
04:47 PM
2014-08-18
04:47 PM
Hi iNTXIXU and Irms,
Please get the Status page of the WN3000RP for further investigation.
Message 7 of 7
Announcements
